Author Topic: Inconsistent _metatype application  (Read 3665 times)
« on: May 13, 2010, 05:30:05 pm »
If you open the properties for an Association arc the dialog caption reads:
Association: <arc name>
If you open the properties for an Class vertex the dialog caption reads:
Class: <vertex name>
Now, if you make the Class the Association Class for the Association then BOTH the Association and the Class properties when opened read:
Association Class: <arc name>
and:
Association Class: <vertex name>
respectively.
If you create an MDG and using stereotypes assign a metatype to the arc and the vertex you get:
<arc metatype>: <arc name>
and:
<vertex metatype>: <vertex name>
However, when you make the Class the Association Class for the Association then you get:Association Class: <arc name>
BUT:
Please rectify the inconsistency...
Reported,
If you want to vote for a fix for this, submit a Registered Bug Report or Bug Report
with the same name, leaving a note here to say you've done it
 - so we users have an indication of the level of support.
