Author Topic: Bad toolbar icons  (Read 5006 times)
iselmo
Bad toolbar icons
« on: May 12, 2010, 04:35:38 am »
There are bad toolbar icons after installation. It's been a permanently returning problem since more months.
Re: Bad toolbar icons
« Reply #1 on: May 12, 2010, 08:37:24 am »
Does Tools > Customize > Toolbars > Reset All help?
« Reply #2 on: May 12, 2010, 03:44:10 pm »
I had the same issue. I did the reset thing on V855, and the icons went normal again, but after installation of v856 the undo button had the "save" icon again.
So do we now have to reset the toolbars after each installation?
beginner
« Reply #3 on: May 12, 2010, 05:44:07 pm »
Annoying thing is: each time you re-install EA (upgrade) your toolbar is reset to some default. Obviously sometimes to scratch. Now that I learned for 7.5 where to save the registry to reload it again, 8.0 seems to have a different philosophy (what a word in that context). There needs to be some "Export Reference Data" for the toolbars, options and so on where users can reproduce previous settings.
b.
iselmo
« Reply #4 on: May 16, 2010, 06:09:07 am »
Yes, Reset All helped. Thanks.
mrf
« Reply #5 on: May 17, 2010, 09:17:28 am »
Hi everyone. We've been aware of this problem for a bit now and have put in a large chunk of time in this current build cycle to find out where the problem is and address it.
The fix should be going in next build, but until then resetting toolbars (and resaving custom workspace layouts after resetting toolbars) is the best way around the issue.
Best Regards,
Michael
