Author Topic: EA 8 Patch upgrade fails.  dll missing  (Read 3938 times)
Mr. George S
« on: May 21, 2010, 03:55:17 am »
Tried to update EA to version 8 using the patch.  Unzipped the patch file to the EA directory.  When I ran EA, I got the message EALayout.dll not found and the program EA would not run.  I had to revert back to the previous version.
The EALayout.dll is missing from the patch zip file.
Re: EA 8 Patch upgrade fails.  dll missing
« Reply #1 on: May 21, 2010, 08:23:55 am »
If you are using the patch file, make sure you are unzipping over an already installed version 8 set-up.  The patch file does not contain all files required to run EA and is not intended for upgrading from a previous version.
