Author Topic: Can't set Show Namespace in Profile  (Read 26875 times)
« on: May 25, 2010, 05:19:45 pm »
Although you can set most of the other Diagram Attributes in an  MDGT you can't set [  ] Show Namespace.
This is probably because  [  ] Show Namespace is controlled by the ShowForeign column and not the PDATA or StyleEx columns (which ARE available in the profile).
Reported,
If you want to vote for a fix for this, submit a Registered Bug Report or Bug Report
with the same name, leaving a note here to say you've done it
 - so we users have an indication of the level of support.
elr
Re: Can't set Show Namespace in Profile
« Reply #1 on: January 08, 2025, 11:42:57 am »
Is the command still not effective ?
In its latest version, doc (https://sparxsystems.com/enterprise_architect_user_guide/17.0/modeling_frameworks/custom_diagram_types.html)
still refers to this syntax :
showForeign: string = 1
in step 5 in order to hide namespace
Eric
