Author Topic: SQL error when saving sequence diagram  (Read 4705 times)
« on: November 30, 2009, 08:06:48 pm »
When saving a sequence diagram that contains some messages to operations with a long name and/or a lot of parameters I get an SQL server error: "Bynary data or string would be truncated"
this is apparently caused by the fact that EA stores the whole signature of the operation in the t_connector.Name field which is only 255 characters long.
Obviously this is not enough.
Reported to Sparx.
Re: SQL error when saving sequence diagram
« Reply #1 on: June 01, 2010, 05:41:28 pm »
Still not fixed in 8.0.856 >:(
I've sent a reminder email to Sparx.
Krayol
« Reply #2 on: June 01, 2010, 09:22:20 pm »
I know that Sparx try to keep databases unchanged so they are perhaps reluctant! :)
I've not come across this, but it sounds as if the object layer and data access mappings/ORM are okay, but that Sparx have simply not created the database with a large enough field.
If so, then as a temporary workaround users could probably just increase the field size themselves.  Since SQL Server 2000 the limit is 4000 unicode characters (and 2008+ are effectively unlimited; nvarchar(max)).  It probably needs a table recreate though.
Of course a better fix might be for the Sparx team to pass in a shorter name!
« Reply #3 on: June 01, 2010, 10:03:46 pm »
Well, I'm very reluctant to change the database schema.
I'm sure that would get me in all kinds of trouble with upgrades, model transfers and gods knows what else.
So I rather live with the bug for now then change the database to something non-standard.
« Reply #4 on: June 02, 2010, 11:08:39 am »
Well, I HAVEN'T been reluctant to change the DB Structure (since it's self-inconsistent anyway - as is the code that uses it...  see: Inconsistencies in Repository technologies - especially the post on t_diagramlinks.IsHidden ) and yes, there are occasional problems.  But that not withstanding - I, too, would caution against making Name any larger than 255 characters.  NOT all the DB technologies allow generating indexes on columns larger than 255 characters.
