Author Topic: HTML Export Duplicate Packages  (Read 11096 times)
AdamO
« on: May 14, 2010, 01:14:16 am »
The export was working fine before I upgraded to version 8.0.856. Prior to this i was using V7.5.
Now whenever I do a HTML export of my model some of the packages in my Use Case Model are duplicated. They are not duplicated within EA just in the exported HTML.
It appears that the duplicated packages are linked in some way as when I expand a package the other duplicate package also expands.
Is this a known issue with V8? Is there a work around?
For your information I am using EA Corporate Edition.
Thanks!
Adam.
AdamO
Re: HTML Export Duplicate Packages
« Reply #1 on: June 14, 2010, 08:42:43 pm »
Has no one else had this issue?
« Reply #2 on: June 14, 2010, 11:06:45 pm »
Have you done a Tools|Data Managent>Project Integrity Check... [Shift+F9]?
If there are any detected integrity problems, then "all bets are off"...
AdamO
« Reply #3 on: June 14, 2010, 11:17:09 pm »
Running that I get the following:
| Integrity Check Report.
| Generated: Monday, 14 June, 2010
| No. Items: 10
1 - Invalid operation parameter. ITEM: InternalTradeID. ACTION: Delete Operation Parameter.
2 - Invalid operation tag. ITEM: property. ACTION: Delete Operation Tag.
3 - Invalid operation tag. ITEM: property. ACTION: Delete Operation Tag.
4 - Invalid link geometry. ITEM: Missing Diagram. ACTION: Delete Invalid Link Geometry.
5 - Invalid connector. ITEM: Association. ACTION: Delete Connector.
6 - Invalid connector. ITEM: Association. ACTION: Delete Connector.
7 - Invalid connector. ITEM: Association. ACTION: Delete Connector.
8 - Invalid connector. ITEM: Association. ACTION: Delete Connector.
9 - Invalid connector. ITEM: Association. ACTION: Delete Connector.
10 - 4 elements: child package ID does not match parent. ITEM: . ACTION: Reset child element Parent ID.
Is there any way to get a more detailed report as I have no idea where the problems are?
Is there not a way just to rebuild the project databases somehow?
Adam.
AdamO
« Reply #4 on: June 14, 2010, 11:23:50 pm »
I have just taken a copy of my project and ran the 'Recover/Clean' option of the 'Project Integrity Check'. The 'Report' now says 'No problems found'.
After doing this I still get the same problem. Any other ideas?
« Reply #5 on: June 15, 2010, 10:09:56 am »
You'll have to send your repository to Sparx for them to analyse what may be the problem.
I've never heard of anything like this.
« Reply #6 on: June 15, 2010, 02:25:20 pm »
We had a similar problem with RTF document generation.
Sent a test case as a repository and it was acknowledged as a bug.
