Author Topic: Importing EMX from RSM - multiple problems  (Read 3348 times)
cty
« on: June 23, 2010, 01:02:58 am »
I am trying desesperatly trying to import files from RSM.
While importing an EMX file - using the "import EMX/UML2 files" button in the "import package from XMI" menu - I encounter the following problem : associated EFX files, which are referenced in the EMX main files - seems not to be accessed by EA. None of the objects defined in these efx files is imported... By the way, these efx files are located in the same folder than the EMX file
While trying to import efx files one by one, I have the following errors displayed :
  • sometimes a "Error description = xsi:nil attribute on element 'element' is invalid" appears
  • sometimes "XMI import failed due to one or more errors", with ... nothing abnormal in the log file
If I open the EMX file with a xml editor, the versions tag I can see are :
xmi:version = 2.0
<signature id="com.ibm.xtools.uml.msl.profile" version="7.0.0"><feature description="" name="com.ibm.xtools.ruml.feature" url="" version="7.0.0"/></signature>
I don't have any idea, for the moment, of the version of RSM used by the people that send these emx/efx files to me.
Any idea from your side ? Didn't find any information anywhere...
thanks in advance for your help.
Ronan
