Author Topic: Diagram Frame - Trapezoid Title Block - Truncation  (Read 3575 times)
MichaelJRoman
« on: July 28, 2010, 02:42:19 am »
Newbie question.
I'm having trouble with diagram titles being truncated within the trapezoidal title block of diagram frames.
Sometimes the trapezoid expands to accept relatively long titles.  Sometimes the trapezoid doesn't and a relatively short title is truncated.
Is there a way to control this behavior?
Re: Diagram Frame - Trapezoid Title Block - Trunca
« Reply #1 on: July 28, 2010, 08:45:02 am »
I can reproduce that when the diagram title is wider than the diagram contents. If I make the diagram contents wider (e.g. move the left-most and right-most objects further apart) then the diagram frame gets bigger and so does the title block. Is that what you're seeing? If not, is there any particular type of diagram that is causing you problems? And is it when you copy, save or print your diagram that you see it?
