Author Topic: DAO.Field [3163]  The field is too small ...  (Read 5896 times)
Dale Sherwood
« on: August 06, 2010, 01:30:46 am »
I just started getting the following EA dialog pop-up in a project that has had no problems until today. The dialog pops up whenever I try to change the Feature Visibility of a specific class X on a specific diagram--I am trying to hide all attributes and operations--and every time I try to save that diagram. I do not get the dialog when I change the visibility of class X on another diagram.
--EA------------------
DAO.Field [3163]
The field is too small to accept the amount of data you attempted to add.  Try inserting or pasting less data.
--OK------------------
The most recent action that might have triggered this: yesterday I used Code Engineering to import a source directory containing 9 classes. (Class X is not one of them; I generated it from EA and periodically sync it with the source.)
I tried various model searches to try to track it down, but no luck. I ran a Project Integrity Check and repaired all problems, and also did a Repair EA File, but it was no help.
How can I track down what is causing this?
Dale Sherwood
Re: DAO.Field [3163]  The field is too small ...
« Reply #1 on: August 06, 2010, 01:55:42 am »
I have discovered a workaround for this issue.
The problem appears to be with class X. It occurs whenever I un-check the All option for Operation Visibility on the Feature Visibility dialog. If I instead select All then customize it by selecting All in the Suppress Features in Diagram dialog, I have no problem.
