Author Topic: C++ Code Engineering Bug: "inout" parameter  (Read 3545 times)
Rene T.
« on: August 20, 2010, 09:26:07 pm »
Aloha!
I think I found a bug in EA's code engineering part:
REPRODUCE:
1. Create a class diagram.
2. Create a class.
3. Add a method to the class.
4. Add a integer parameter to the class, define it as "inout" parameter.
5. Export the class as C++ code.
PROBLEM:
In the diagram, the method's parameter is correctly shown as "int *". However, the exported code contains just an "int" parameter.  :o
Anybody observed that as well?
Re: C++ Code Engineering Bug: "inout" parameter
« Reply #1 on: August 23, 2010, 08:17:26 am »
C++ code engineering does not use the parameter direction.  A search should be able to find other reports of this behavior and why it hasn't been done.
