Author Topic: Version 3.60 - Build 641 Released  (Read 23364 times)
sparks
« on: September 11, 2003, 09:50:57 pm »
Changes and Fixes in Version 3.60 - build 641
Fixed C++ Rev Eng : Incorrectly parsed attributes with nested template types
Modified Use Case drawing to hide extension points when diagram option "Hide Attributes" is checked
Removed namspace blank line in DDL generation for Oracle
Fixed missing attribute name on associations with multiple primary keys
Fixed error in import of tables where more than one foreign key relationship existed between two tables
Fixed bug that could cause Operations and Attributes dialog to abort when Alt+C pressed
Fixed problem with buttons to move method params up and down being disabled
Fixed issue with UI when changing visual layouts that have docked tear-off menus showing
Modified use of stereotype colors to work when base class type is not matched in target element
Fixed caption display of sequence diagram so that when diagram is scrolled, element captions in title are correctly positioned
