Author Topic: Status values  (Read 3580 times)
tshan
Status values
« on: August 26, 2010, 06:59:35 am »
I am using 8.0.859
I used the Export Reference Data to create an xml file which contains Status Values.
When I import that data into a new project, the Status Values are not available for selection from the Status drop down list on the properties screen for a requirement.  Only the default values are available.
If you check the Settings > General Types screen, my status values are there.
In order to make them available from the drop down list, I have to go to Settings > General Types, edit one of the Status Values (eg change a description for one of the Statuses) and save that change.  Then all the new status values are available for selection for a requirement.
Tom
