Author Topic: Add hyperlink / Limited selections  (Read 4184 times)
RainerQ
« on: September 01, 2010, 05:10:15 pm »
Hi
as I want to add a diagram hyperlink to a diagram, I don't get all my diagrams in the "Select a Diagram" dialog even though "Visible Diagram Types" is set to "<All>".
It seems to be the way, that only diagrams which have already been opened in the session are provided.
I think this is a bug. ;)
Some details:
EA Version : 8.0.862
Steps till the issue occurs:
- Opened EA- Model then open activity diagram.
On a open activity diagram
- select hyperlink from tool box
- click on diagram
- Hyperlink Detail Dialog -> Type = Diagram
->> Issue : Select a diagram dialog only shows a subset of my model
Hope that helps to reproduce the issue
Regards
Rainer
Re: Add hyperlink / Limited selections
« Reply #1 on: September 02, 2010, 08:19:21 am »
If you open the options dialog (Tools | Options) you can select the 'Model Loading Strategy'.  Set this to 'Pre-load entire model' and it should work again.
RainerQ
« Reply #2 on: September 02, 2010, 04:23:27 pm »
Hi Simon,
thanks for the information. With "Pre-load entire model" it works.
Regards
Rainer
