Author Topic: EA8 - SVN Check Out Problem  (Read 4013 times)
Jon Y
« on: August 06, 2010, 06:00:15 pm »
Good Morning all,
When trying to check out a packing in EA8 (Trial) using SVN, I'm presented with an error message saying:
"The selected package cannot be checked-out at this time.
The configuration 'scoris-SVN' reports the file 'myModel,xml as not 'Not Controlled'.
However, these files have been source controlled for many years and worked fine in EA7 (only since the upgrade has this happened) and can be checked out etc in Tortoise.
Can anyone please help?
Jon
ChrisM
Re: EA8 - SVN Check Out Problem
« Reply #1 on: September 06, 2010, 05:23:19 pm »
I have the same problem using CVS on a local repository - I have added the project to source control and that worked fine - I can bring up the status and Get Latest but when attempting to checkout or re-sync with VC status, it always reports as uncontrolled but the package symbol stays as locked. I am using version 8 build 857
Jon Y
« Reply #2 on: September 06, 2010, 05:55:20 pm »
Hi Chris,
I sorted my problem out. It was my mistake, I didn't have the repository setup right - I needed to go to the Trunk folder. Once this was done, it worked fine.
ChrisM
« Reply #3 on: September 06, 2010, 07:17:22 pm »
Maybe mine is a different problem then - I created a configuration then added the project to version control and that all worked. I would have expected that to fail if the setup was wrong.
