Author Topic: HTML Report GUID style linking fails  (Read 4035 times)
hipgeek
« on: October 19, 2010, 09:28:13 pm »
We are on 7.5.849 and ee export HTML models and then publish them via Tomcat.
What we have found is that the guid style linking does not work once published, but it does work straight off the file system:
This works:
file:///C:/Documents%20and%20Settings/traja/Desktop/POS_HLD_Models_V03.6/index.htm?guid=6A8D94C5-1744-434f-9F10-FF8FBC9C531E
But this does not
http://projects/posmodels/POS_HLD_Models_V03.6/index.htm?guid=6A8D94C5-1744-434f-9F10-FF8FBC9C531E
This is due to fact that through Tomcat the case of file name is important, so if we edit the guid and change it to be:
http://projects/posmodels/POS_HLD_Models_V03.6/index.htm?guid=6a8D94C5-1744-434f-9F10-FF8FBC9C531E
It works. A fix to exported JS needed.
Cheers
Adrian
hipgeek
Her is the updated displayToc.js line 87
« Reply #1 on: October 19, 2010, 09:31:15 pm »
var tocRoot, tocBranch, tocSel, tocLoading, tocLastID, tableSel, tabHead, data, tocTab, tocInitRoot, tocMemToc, rFStatus, oldData, tableSelTable;
var initI;
var icon=new Array();
var preloadIcons=new Array(1,10,101,102,103,104,106,107,108,11,113,116,118,16,175,176,177,178,179,180,181,182,183,184,185,186,187,188,189,19,20,21,24,25,26,28,29,31,34,4,5,52,53,56,57,6,60,68,69,7,8,82,9,99);
var browser=browserCheck();
var content=0;
var Linkguid="";
function browserCheck() {
      browser=navigator.userAgent.toLowerCase();
      if (browser.indexOf('msie')!=-1) {
            if(browser.substring(browser.indexOf('msie')+5,browser.indexOf('.',browser.indexOf('msie')))>6) return("ie7");
            if(browser.substring(browser.indexOf('msie')+5,browser.indexOf('.',browser.indexOf('msie')))>5) return("ie6");
            else return("ie_old");
      else if (browser.indexOf('firefox')!=-1) return("ff");
      else if (browser.indexOf('opera')!=-1) return("op");
      else if (browser.indexOf('gecko')!=-1) return("ff");
function changeCSS(theClass,element,value,target) {
      var cssRules;
      target = eval(target+'.document.styleSheets');
      if (browser=='ie6'||browser=='ie7') {
            cssRules = 'rules';
      } else if (browser=='ff'||browser=='op') {
            cssRules = 'cssRules';
      for (var S = 0; S < target.length; S++){
            for (var R = 0; R < target[cssRules].length; R++) {
                  if (target[cssRules][R].selectorText == theClass) {
                        try {
                              target[cssRules][R].style[element] = value;
                        } catch(e) {}
function initItem(item) {
      tableSel=null;
      if (cont.document.getElementById('TableGroup')!=null) {
            toggleItem(cont.document.getElementById('TableGroup').getElementsByTagName('li')[0].id.replace("Title",""));
function initLoad(src,toc,home) {
      var qs=document.location.search.substring(1);
      if (qs.substring(0,qs.indexOf('='))=='goto') {
            var gotoPage = qs.substring(qs.indexOf('=')+1).split(':');
            var fExt = home.substring(home.lastIndexOf('.'));
            var home = "./EARoot/";
            for (var i=0; i<gotoPage.length; i++) {
                  home += "EA"+gotoPage;
                  if (i!=gotoPage.length-1)
                        home += "/";
                  else
                        home += fExt;
      content = document.createElement('div');
      content.className = "IndexBody";
      content.innerHTML="      <iframe src='"+toc+"' name='toc' id='tocIFrame' frameborder='0'></iframe>\n";
      if (qs.substring(0,qs.indexOf('='))=='guid') {
            Linkguid = qs.substring(qs.indexOf('=')+1).split('?guid=');
            LoadGuidMap(OnReadyLoadGuidMap);
      else{
            // We don't have a guid in the address bar, so set the default homepage and continue
            content.innerHTML+="      <iframe src='"+home+"' name='cont' id='contentIFrame' frameborder='0'></iframe>";
            content.innerHTML+="      <div id=\"resizeFrames\"></div>";
            // Pass in the guid of the home page or class.
            initPreLoad(content);
function LoadGuidMap(ResponseFunc){
      // Get the correct file
      var FirstTwoHexDigits = new String(Linkguid);
      FirstTwoHexDigits = FirstTwoHexDigits.slice(0,2);
      var src = "js/data/guidmaps/"+"GuidMap"+FirstTwoHexDigits.toLowerCase()+".xml";
  RequestPage(src,ResponseFunc);// Request the page passing in the filelocation and the response function.
function OnReadyLoadGuidMap(){
      if (data.readyState == 4){
            try{
                  var Home = GetPageAddressFromMapString(data.responseText);
                  //Set the home page.
                  content.innerHTML+="      <iframe src='"+Home+"' name='cont' id='contentIFrame' frameborder='0'></iframe>";
      //Make sure memory for the string is cleared. The browser should do this anyway but just in case.
      Home=null;
                  // Continue loading the rest of the page.
            catch(e){
                  return;
function GetPageAddressFromMapString(MapString)
      var LG = new String(Linkguid);
              var Page = new String(MapString);
              LG = LG.toLowerCase();    //Make searching case insensitive.
              Page = Page.toLowerCase();
                  var Pos1 = Page.search(LG);   // Search the the guid in the string and return the position.
                  Page = Page.slice(Pos1);// Remove the top half of the string.
                  var Pos2 = Page.search("/");  //Search for the start of the web address.
                  var Pos3 = Page.search(";");  //Search for the end of the web address.
                  Page = Page.slice(Pos2+1,Pos3);   // extract the web address.
                  // Leave the page address in the original case as Linux is case sensitive.
                  Pos1 = Page.search(".htm");
                  Page = Page.slice(0,Pos1);
                  Page = Page.toUpperCase();
                  Page = "EARoot/" + Page + ".htm"; // At the root back onto the page.
                  return Page;
function guidLink(guid,qs) {
  guid = guid.substring(1,guid.length-1); //Remove the brakets
      Linkguid = guid;
      LoadGuidMap(OnReadyGuidLink);
function OnReadyGuidLink(){
    try{
      // Get the page location from the guid map.
      var Page = GetPageAddressFromMapString(data.responseText);
      cont.location = Page;
alesliehughes
Re: HTML Report GUID style linking fails
« Reply #2 on: October 21, 2010, 10:10:49 am »
This issue was fixed in EA 7.5 Build 845.
Corrected ability to search by GUID, for generated HTML documentation in web browsers under Linux.
