Author Topic: Access Windows Authentication  (Read 4215 times)
Bella
« on: October 26, 2010, 01:06:39 am »
We use the corporate edition of EA and the user authentication for the SQL server has been switched of by one of the Administrators (i suspect) accidently.  As a result no one can access the EADB :'(.  We don’t have a supper user setup in EA (although on the server but this is useless :() that can access the DBwithout windows authentication.  Can anyone provide me with the SQL script to update the flag on the DB?
Re: Access Windows Authentication
« Reply #1 on: October 26, 2010, 04:29:17 pm »
Bella,
I'm not getting the problem. What did the Admin turn off exactly? And why can't he just turn it on again?
And which flag are you looking for to enable/disable?
Anyway, anything related to users in EA is stored in the tables
t_secuser, t_secpermission, t_sec...
t_secpolicies might be interesting as you can turn UserSecurity off there.
Bella
« Reply #2 on: October 26, 2010, 04:56:04 pm »
Thanx Geert
Problem where the DB admin don't have access to the front end and they don't understand the EA Base DB structure i.e. the tables you mentioned.  However I where able to access the front end and switch on the Accept Windows Authentication check box again by getting access to the SQL DB first & thereafter accessing the front end with a password. All is well now.  Any idea where one can find a data dictionary of the EA SQL Base? :D ::)
« Reply #3 on: October 26, 2010, 05:15:33 pm »
There is no such thing, but I suspect that
update t_secpolicies set value = 'Disabled'
where Property = 'UserSecurity'
will turn user security off completely.
This allows you to login to EA without user login.
