Author Topic: Adding Diagrams to class operation  (Read 4616 times)
kam
« on: November 05, 2010, 08:27:27 pm »
I'm a software engineer and use EA for documentation of some complex classes in a realtime environment. To give better understanding of class operations, I'd like to add an activity diagram to that.
Any hint why it is not possible to add a new diagram but to paste an existing diagram to the class operation ?  :-[
Thanks a lot
karl
« Last Edit: November 05, 2010, 08:28:25 pm by kam2630 »
Re: Adding Diagrams to class operation
« Reply #1 on: November 05, 2010, 08:34:25 pm »
Karl,
I don't understand your question exactly.
Where do you want to add a diagram?
In EA you can only add diagrams nested in Elements or diagrams, not nested in an operation or an attribute.
kam
« Reply #2 on: November 05, 2010, 08:50:49 pm »
Gert,
I created a class "Class1" into a package and added an operation "op1" into this class.
If I do a right click onto this operation I'll get a popup menu,
allowing to paste a previous copied diagramm; but it seems not to be allowed to start a new one here.
If it is not allowed to do so, how is the "correct" way to combine a class operation with an activity diagram ?
thks,
karl
« Reply #3 on: November 05, 2010, 09:06:12 pm »
Karl,
If you reload the model you will notice that the diagram isn't there anymore. Apparently this is a bug in EA to allow the "paste diagram" command on operations.
There are many ways to link behavior to an operation. What you could do is
- Create an Activity with a nested Activity diagram
- Go to the Behavior tab of the operations properties
- Click on the [...] button and select the previously created Activity
kam
« Reply #4 on: November 05, 2010, 10:20:10 pm »
Geert,
I'm not really satisified to do it like that, but at least it is a way.
Thks,
Karl
« Reply #5 on: November 05, 2010, 10:53:45 pm »
Karl,
If you're not happy about that you'll need to talk to OMG, because that is the way it is designed to work in UML.
