Author Topic: RTF Generator Diagram Elements vs Elements Tag  (Read 3610 times)
skylord88
« on: November 15, 2010, 07:29:12 pm »
Hi I am running in a odd problem, according to a whitepaper on the sparx
website the following setup in a rtf template is possible in order to put more detailed information into a rtf reporit (e.g. requirements of an element)
- start a diagram tag to put the diagram image in the document for example
- within the diagram section select "elements"  but add no fields in this section.
- select the package / elements section and add all required fields there
according to the WP the RTF generator should now use all elements in the diagram and apply the rtf generator settings of the package / elements section to it.
Having such a document template I run into the problem that the RTF generator seams to "forgett" some diagram elements, Anyone has any hint how to fix this?
thanks
alesliehughes
Re: RTF Generator Diagram Elements vs Elements Tag
« Reply #1 on: November 16, 2010, 08:52:09 am »
Please send support the details of the issue and include a copy of the template in question.
