Author Topic: Diagrams in RTF Report Shrank!  (Read 7620 times)
AlanT
« on: November 12, 2010, 01:16:54 pm »
I have been using an RTF document template for use cases, for quite some time.  Now, all of a sudden, ALL the diagrams are smaller in the RTF output than they used to be.  I checked the diagram settings, which should not have changed, but I cannot find a problem.
    Has anyone else experienced this?       Thanks, Alan    :'(
AndyJ
  • It's only a model
Re: Diagrams in RTF Report Shrank!
« Reply #1 on: November 12, 2010, 03:06:07 pm »
Alan, I'm not sure it's the identical issue, but similar...
I noticed today, when exporting via RTF and then pulling in to MSWord, the diagrams were very small.
I resized them in Word, and subsequent updates seem to be coming in at the correct size.
I've been fiddling with similar issues where Word is ignoring a subset of styles, until I manually set them (for example table heading in the rtf is changed to normal in Word). Once I've manually changed them once, subsequent imports work!
I'm wondering if there has been an update to Word that is making weirdness happen.
« Last Edit: November 12, 2010, 03:06:38 pm by novaphile »
AlanT
« Reply #2 on: November 12, 2010, 10:25:54 pm »
  It turns out that my Diagram Format (EA RTF doc gen window, Advanced tab) keeps getting reset to "Metafile", after I change it to "Bitmap."  If I change that right before I generate the document, they come out fine.  However, once I leave the RTF doc gen window, it reverts to "Metafile."
Weird!    At least I have a workaround now.
        Alan  :-?
« Reply #3 on: November 12, 2010, 10:35:55 pm »
Formally report the bug using the links below.
Sounds like EAUI.
« Reply #4 on: November 15, 2010, 08:41:21 am »
Sounds like you don't realise the image format is saved in the template being run and that the settings on the dialog allow you to override those options for the single run of the generator.
AlanT
« Reply #5 on: November 15, 2010, 01:39:56 pm »
I did report this.  (Reference # 10117461)
           Alan
AlanT
« Reply #6 on: November 15, 2010, 01:44:32 pm »
Simon:  Where do I change this in the document template?
Thanks, Alan
AndyJ
  • It's only a model
« Reply #7 on: November 15, 2010, 02:00:49 pm »
Assuming that the template is yours and therefore editable.
Open the template editor and select: File|Document Options|Diagram Format (It's about the second line from the bottom of the "Document Options tab, near the centre)
Happy
« Reply #8 on: November 15, 2010, 11:15:59 pm »
We detected that the size of diagrams in generated RTFs also depend on the display layout for the first monitor.
RTFs generated on a 24" monitor are differently generated (much smaller) than generated on 19" monitors.
AlanT
« Reply #9 on: November 17, 2010, 02:21:47 pm »
Andy,
          Thanks.  That worked.         Alan
