Author Topic: Rich text documentation - heading levels  (Read 3333 times)
Karsten@Thrane
« on: April 26, 2006, 06:31:09 am »
Hi all you Gurus  ;)
I have problems using a customized RTF document template (Generate RTF Documentation - Use Template) and the heading levels being generated in the document.
I would expect that the packet names resulted in section headlines at the relevant level depending on the deepth of the packet. In the "Generate Options" dialog the field "Adjust Heading Level" is set to "Heading 9" (but I have tried all the combinations).
Regardless of this the generated document only uses the "Normal" style on all the headings.
If I generate the documentation using the "Rich Text Format Report" (by pressing button "Switch Generator" in the "Generate RTF Documentation" dialog) and select "Heading Style" = "Max 9 levels - elements are package+1" then everything works as I would expect, but I would rather customize the template myself.
Why can I not get the packet levels to use the Heading styles when I use my customized template ???
