Author Topic: ActivateDiagram should return result  (Read 3681 times)
« on: November 24, 2010, 02:00:55 pm »
As discussed in: How to detect an already open diagram
ActivateDiagram should not open a diagram that isn't already open.
And this is, in fact, the case.
However, it should return at a result indicating whether the diagram was able to be activated or not.  This would allow a simple test of whether a diagram is already open or not.
If it returned the same result as IsTabOpen, it would provide the most information - but even a simple boolean would be beneficial.
Even GetLastError()is silent on the matter - even if the diagram was NOT open.
NOTE: IsTab open is not sufficient to uniquely identify the diagram (as discussed in the Forum reference above)
Reported,
