Author Topic: Debugger  (Read 4646 times)
pirlina
Debugger
« on: April 21, 2006, 09:00:08 am »
Hi, I have a big problem: when I try to start a debug session, after configured it as on manula, I always get "OnDebugRun failure".
Please, any suggestion?
Thank you
Claudia
Re: Debugger
« Reply #1 on: April 23, 2006, 03:06:30 pm »
We'll need more information before we can help.
What language/version are you attempting to debug?  Has the source code been imported into your model?
Has it been compiled correctly?
agudenus
Re: Debugger
« Reply #2 on: April 26, 2006, 08:12:16 am »
Hi
We have got the same problem. Our setup looks like this:
- Java 1.5
- EA 6.1 Corporate Ed.
- MDG Link for Eclipse 1.1.19
- Source reverse engineered with MDG Link for Eclipse
We are trying to debug a junit testcase to record a sequence diagram.
When we run "test" it works, but the settings for debugging a testcase are not really intuitive ;)
Maybe we have to write a main method for running the testcase?
thx for your help
lidia & alex
Re: Debugger
« Reply #3 on: April 26, 2006, 02:54:15 pm »
To debug a test case you'll need to reverse engineer your JUnit code, and set up a build/run/debug script specific to that.
agudenus
Re: Debugger
« Reply #4 on: April 27, 2006, 12:54:58 am »
We did that!
I suppose the script is wrong:
test:
java -ea -Xmx512m -cp "very long classpath" junit.textui.TestRunner %N
run:
java -ea -Xmx512m -cp "very lonmg classpath" junit.textui.TestRunner TestXMLWithoutContainer
debug:
vars
jre="C:\Program Files\Java\jdk1.5.0_05\jre\bin" -Djava.class.path="very long classpath"
it seems that ea can find the testclass but is not able to execute it.
Any hints?
thx
alex
Re: Debugger
« Reply #5 on: April 27, 2006, 03:41:47 pm »
No great ideas.
What command line would you use to debug it using the JDK directly?
