Author Topic: Python code import issues in EA v8.  (Read 3478 times)
Olly B
« on: January 08, 2011, 04:35:05 am »
When attempting to import/reverse engineer some Python code into the trial version of EA 8.0.864, I found some errors parsing perfectly working and executing (on a python 2.6.5 interpreter) code:
The following snippets have been copied to a separate file, with the parse error occurring in just these snippets.
1      class class1(object):
2
3              def __init__(self,param1=0L):
4
5                  if isinstance(param1, str):
6                      var1 = long(param1,16)
7                  else:
8                      var1 = long(param1)
There was an error parsing <path_to_file>\class1.py on line 7.  Unexpected symbol: :
1      class class2(object):
2
3          @property
4          def attrib1(self):
5              retVal = self.attrib1
6              return retVal
7
8          @attrib1.setter
9          def attrib1(self, value):
10              self.attrib1 = value
There was an error parsing <path to file>\class2.py on line 8.  Unexpected symbol: .
(NB: line 8 - "@attrib1.setter" parses fine if the attrib1 getter method isn't present)
1      class class3(object):
2
3          def method1(self, arg1, arg2=lambda a: a):
4              self.attrib1 = arg1
5              self.attrib2 = arg2
6
There was an error parsing <path to file>\class3.py on line 5.  Unexpected symbol: <<DEDENT>>
With the real file that was being imported, I got the following, but can't recreate it in the code snippet (line number corrected to line numbers above):
There was an error parsing <path to file>\<filename>.py on line 3.  Unexpected symbol: :
Please could you investigate. In all cases I would expect the code to be parsed without issue.
Olly
