Author Topic: V8 Does Not Print External Reqs from Other Package  (Read 5127 times)
Matt Pequignot
« on: December 30, 2010, 07:51:32 am »
I had created a template using Version 7.5.850 and it worked the way that I needed it too. As expected, the generated documentation pulls in requirements from other packages as long as they are attached to a Use Case (meaning, on the Requirements Tab) in the package from which I am printing. However, using the exact same template in Version 8.0.864 yields different results. All of the selections on all of the "Generate RTF Documentation" dialog box are set to the same settings when attempting to compare the outputs, so there is nothing there that would cause a difference in the outputs.
alesliehughes
Re: V8 Does Not Print External Reqs from Other Pac
« Reply #1 on: January 04, 2011, 11:26:34 am »
Yes, there has been changes that could cause this issue.
Try checking the option "Include all diagrams elements in report" on the RTF Generate dialog.
Alistair
Matt Pequignot
« Reply #2 on: January 05, 2011, 02:58:53 am »
That option is checked but still does not receive the expected result (meaning, the results are different than versions previous to V8). Thank you.
M
« Last Edit: January 05, 2011, 03:04:29 am by mpequignot »
alesliehughes
« Reply #3 on: January 05, 2011, 08:10:07 am »
Does your template have the "Diagram -> element" section enabled?
If not, try inserting it.
Matt Pequignot
« Reply #4 on: January 22, 2011, 09:44:50 am »
Yes, all of the selections are the same in 7.5.850 and  8.0.864 and I get different results.
M
alesliehughes
« Reply #5 on: January 24, 2011, 08:17:02 am »
Please send a email to support with the issue, and a copy of the template in question.
