Author Topic: Use Case RTF Issue  (Read 6172 times)
brucebanner
Use Case RTF Issue
« on: January 28, 2011, 09:19:21 pm »
I am attempting to create a Use Case template for my company using the standard Use case template included in EA as a starting point.
One of the things I would like to alter is how the structured specification is displayed in the RTF.  Currently it displays the steps as below:
Basic Path:
1 Player does this. 2 System does that. 3 Player does this. 4 System does that. 5 Player does something else.
I would like it to display it as a list:
Basic Path:
1 Player does this.
2 System does that.
3 Player does this.
4 System does that.
Is there a way to do this?
Cheers
AndyJ
  • It's only a model
Re: Use Case RTF Issue
« Reply #1 on: February 02, 2011, 09:29:28 am »
Hi Bruce (mental note: don't make Bruce angry...)
The easiest way is to embed the Structured Scenario into a table in your rtf template.
In my case, I have a table which is headed: Step, Description, Uses
and contains in the cells (in a single row) Scenario_Structured.Step Scenario_Structured.Name Scenario_Structured.Uses
This lays out the use case very nicely.
Andy
« Reply #2 on: February 02, 2011, 11:55:14 am »
If you mean THE bruce...  Then one way is to call him Bruce...   ;)
He's bruce!
I had to add bruce to my spell checker...  ;D
vjr
« Reply #3 on: February 02, 2011, 01:48:56 pm »
The use case scenario template formats it the way you've specified. However, I can't get it to display Exception paths in the basic path the way it does Alternate paths (although, it incorrectly displays "Exception:" instead of "Alternate:" for alternate scenarios.)
« Last Edit: February 02, 2011, 01:49:59 pm by vjr »
brucebanner
« Reply #4 on: February 02, 2011, 07:53:40 pm »
Hi Guys
Sorted the issue with the steps (thanks Andy J) and have also noticed the mixup in the Exception and Alternate paths.  Nearly there though :-)
thanks guys
