Author Topic: Use Case Scenario pre/post conditions  (Read 8709 times)
PaulStevenson
« on: January 21, 2011, 11:09:21 pm »
Is there a way of specifying individual pre/post-conditions for structured scenarios in a Use Case in EA?  I have a few for which post-conditions in particular differ depending on the alternate chosen.
Thanks for any help you can give me.
Re: Use Case Scenario pre/post conditions
« Reply #1 on: January 24, 2011, 05:19:24 pm »
Paul,
I don't think you can. We use a naming convention to define pre/post conditions for specific scenario's.
vjr
« Reply #2 on: February 02, 2011, 02:19:52 pm »
Go to your use case properties, choose Constraints tab, select Pre-condition or Post-condition from 'Type' drop-down. Type the pre/post condition details in the 'Constraint' edit box.
Edit: just read your post properly. Does UML allow that? It seems a bit of overkill.
« Last Edit: February 02, 2011, 02:24:01 pm by vjr »
« Reply #3 on: February 02, 2011, 02:39:36 pm »
AFAIK use case scenario's are not UML defined artifacts, so attaching constraints to them would be outside of standard UML.
PaulStevenson
« Reply #4 on: February 02, 2011, 09:58:07 pm »
Hi thanks for your help everyone who contributed.  Is it overkill?  I would expect each end-point in a use case would have a different set of postconditions.
We've got around this using the scenario descriptions now.
Thanks again!
Paul
« Last Edit: February 02, 2011, 09:59:04 pm by paulstevenson »
vjr
« Reply #5 on: February 03, 2011, 10:38:16 am »
It's true that scenarios are not defined in the UML. My interpretation is that the 'pre-condition' of an extension use case is the condition (constraint) on the extension, if present.
From section 16.3.3
"• condition : Constraint [0..1]
References the condition that must hold when the first extension point is reached for the extension to take place."
This seems to be modelled in EA by the Scenario's name, which is shown as the guard in an activity diagram. An extension use case isn't meant to exist on it's own, so I'd imagine it shouldn't have pre/post conditions. But, whatever works for you  :)
