Author Topic: Issue when generating c code  (Read 3497 times)
christoph75
« on: March 04, 2011, 06:19:24 am »
I'm observing a strange issue when generating C code from a class model (with object oriented support turned on). First time everything looks fine:
typedef struct MyStruct
      int member;
} MyStruct;
After synchronizing with code, the stereotype struct is added to the class and some typedef / typeSynonyms tagged values are created. When forward generating again, the struct appears two times in the header file:
      int member;
} MyStruct;
      int member;
} MyStruct;
Is this a known issue, and if so are there any workarounds known?
Thanks in advance!
