Author Topic: MySQL Repository: ODBC connection fails, EA closes  (Read 11756 times)
Michael Hafner
« on: March 01, 2011, 06:44:04 am »
Dear all,
v8.0: Trying to establish a connection to a MySQL repository, I encounter a problem:
1. MySQL is up an running
2. EA schema is set up in db
3. ODBC driver is installed (MySQL ODBC 5.1 Driver; TCP/IP Server, Port 3306)
4. Test of connection is succesful
5. However, when starting the project transfer, I receive the following message: "Enterprise Architect has experienced a network error and will close down". Not surprisingly, EA closes down after that...
Q #1: What may be the reason for this (and why does EA have to close down in this situation)?
Q #2: I only need to "dump" the project database into a MySQL database; is there any other way to do this (in case the network problem can't be solved)?
Thanks for any help!
Michael
alex_b
Re: MySQL Repository: ODBC connection fails, EA cl
« Reply #1 on: March 02, 2011, 01:42:58 am »
I have got the same problem and am in dire need for a solution.
Alex.
« Reply #2 on: March 02, 2011, 02:30:52 am »
Just the "have you plugged in the terminal"-question: is your repository initialized with EA's resource SQL script?
Michael Hafner
« Reply #3 on: March 02, 2011, 03:35:03 am »
Yes. I have used the script from
http://www.sparxsystems.com/downloads/corp/scripts/MySQL_MyISAM_EASchema.sql
...without any modification. No problems of any kind.
Luis J. Lobo
  • IT Consultant
« Reply #4 on: March 03, 2011, 12:36:42 am »
Have you uploaded an EAP file to MySQL? This is mandatory previusly to try to connect to it.
Michael Hafner
« Reply #5 on: March 03, 2011, 01:02:02 am »
Hi, Luis,
thanks for the reply, but I don't get you. I have to upload an EAP file? - I want to transfer an EA project from an EAP file to a MySQL database. An EAP file is a jet database, right? Now, my documentation tells me to set up a MySQL database via Sparx's SQL script (v.s.), and to connect to it via ODBC. The transfer is (or should be) done by EA: retrieving the data from the jet db, handing them over to MySQL &c.
This is the point where the problem occurs: MySQL schema exists, ODBC driver works, EA transfer fails. Have I missed something?
Best,
Michael
« Last Edit: March 03, 2011, 01:03:02 am by hafnerm »
Luis J. Lobo
  • IT Consultant
« Reply #6 on: March 03, 2011, 01:16:21 am »
The steps are:
1. Create a empty database
2. Run the SQL script
3. TRANSFER SOMETHING (maybe a empty EAP, a template from an EAP or another database...). Use the "Tools | Data Management | Project Transfer" dialog.
4. Connect to the new Repository
The step 3 is mandatory, you must transfer at least an empty model in order to be able to connect in step 4.
Look for the entire process at: (the steps could not correspond with the steps described by me, but describes the same)
http://www.sparxsystems.com/enterprise_architect_user_guide/8.0/projects_and_teams/upsizingtomysql.html
Michael Hafner
« Reply #7 on: March 03, 2011, 01:34:50 am »
The steps are:
Yup. That's precisely what I'm trying to do. Dialog Project Transfer, Transfer Type EAP to DBMS. I select a source project. I then define a target project - selecting Microsoft OLE DB Provider for ODBC drivers, selecting a data source etc. on the way -, test the connection, go back to the Project Transfer dialog, click the "Transfer" button, and bada bing, bada boom, EA crashes.
Luis J. Lobo
  • IT Consultant
« Reply #8 on: March 03, 2011, 01:50:37 am »
Have you checked the "Don't optimize column width" and "Return maching rows" at the MySql ODBC driver?
Michael Hafner
« Reply #9 on: March 03, 2011, 02:14:52 am »
I don't see those options on the details panes (v5.1.8)...
Luis J. Lobo
  • IT Consultant
« Reply #10 on: March 03, 2011, 03:51:02 am »
Check the point 6. here:
http://www.sparxsystems.com/enterprise_architect_user_guide/8.0/projects_and_teams/setupmysqlodbcdriver.html
The options depends on the MySQL driver version, but on every versions they are similar...
Michael Hafner
« Reply #11 on: March 03, 2011, 04:36:11 am »
Thou shalt read the documentation thoroughly...
Luis, if you happen to come to Bonn, don't forget to drop by for a beer. It works.
Now there remains some collation stuff to do, and some duplicate GUIDs seem to have found their way into the project (how on earth...), but I'll deal with this.
A big thank-you to Madrid!
Best regards,
Michael
alex_b
« Reply #12 on: March 04, 2011, 10:13:47 pm »
I could solve our problem (which led to the same error message and crash of EA). I forgot to enter the db name at the msql odbc driver configuration (a small entry on bottom of dialog).
Loading a EAP onto db is NOT necessary for a valid connection (and do not mean the connection test).
Best regards,
Alex.
Michael Hafner
« Reply #13 on: March 04, 2011, 10:42:47 pm »
And wouldn't it be nice if EA didn't crash?
The reasons for a failed transfer may vary, but does any of them justify seppukku?   :)
