Author Topic: Editor: use spaces instead of tabs  (Read 3543 times)
EricP
« on: March 05, 2011, 02:42:21 am »
Can anyone tell me how to set the EA internal code editor to use spaces instead of tabs, and set the number of spaces per tab?
I did it once but then I had to re-install EA and lost that setting, and now I can't find it.
Version is 7.5.850.
Thanks...
Aaron B
Re: Editor: use spaces instead of tabs
« Reply #1 on: March 07, 2011, 10:20:36 am »
For EA 7.5 you will need to edit the appropriate .properties files under the "\Program Files\Sparx Systems\EA\Config" directory.  There is a PDF file in this directory that should provide further help.  See the properties TAB_USE_SPACES and TAB_WIDTH.
EA 8.0 provides the ability to edit these settings directly from the Tools | Options dialog.
http://www.sparxsystems.com/enterprise_architect_user_guide/8.0/software_development/editor_language_properties.html
HTH.
