Author Topic: Bug EA 9 - generating multiple RTF reports fails  (Read 3608 times)
meierch
  • Modeling we can!
« on: March 23, 2011, 03:09:27 am »
Seems that there is no option to report a EA 9 Beta bug directly ... versions stop with EA 8  :(
If I select RTF Documents under Resources and the try to generate all or many reports together (Generate Documents ..., Generate All Documents ...) then the path and file name are not considered for the output (generates to .RTF).  Selecting single documents and then selecting auto generation shows the same failure.  If I use 'Generate Document' then the correct path and filename shows up.  :-[
Regards
Christian
Re: Bug EA 9 - generating multiple RTF reports fai
« Reply #1 on: March 23, 2011, 06:34:37 am »
Beta versions have their own form.
http://www.sparxsystems.com/registered/reg_bug_report_beta.html
However, unless I'm mistaken that issue has already been identified and corrected for the next beta.  Still feel free to send in a bug report if you would like that confirmed.
