Author Topic: Need Indicator for Tagged Value Notes  (Read 3542 times)
« on: April 07, 2011, 01:47:43 pm »
Making the Notes visible at the bottom of the Tagged Values window when the Tagged Value is selected is also very good.
However, there needs to be an indicator against each tagged value entry to indicate there ARE notes attached.  In a big list of Tagged Values against an item, users aren't going to select each one JUST to see IF there is a note attached.
Since the addition of such a note means that the users is implicitly suggesting there is something of importance here should mean that there should be some higher level indication of that.
Submitted,
