Author Topic: Enterprise Architect has experienced a network err  (Read 15640 times)
kkilpone
  • Simpsons rocks
Re: Enterprise Architect has experienced a network
« Reply #15 on: May 12, 2006, 12:07:03 pm »
Can I convert the EA file to Access 2000 file format and still be able to use it in EA?
« Reply #16 on: May 12, 2006, 01:47:25 pm »
Maybe this is a Jet4 issue. EA normally doesn't use Jet 4.0. You have to set this in the General Options and restart EA.
« Reply #17 on: May 12, 2006, 02:18:06 pm »
Thomas may be right about this. I always set EA to use Jet 4.0 so I cannot say if the default setting is different.
I do know that Access will complain about the format regardless of the EA setting. As I mentioned in my earlier post you will have to let Access convert the file to the current format. After that you can try the repair. Finally, you will have to get access to export or convert (I cannot remember which way Access refers to the operation) the file back to a previous format - Access 97 has worked for me.
I have only tried this with Access 2000, so cannot say if it will work with 2003. You'll have to try that on your own.
