Author Topic: Creating/accessing linked docs via COM?  (Read 4949 times)
owieland69
  • Don't eat the yellow snow
« on: May 15, 2006, 03:12:46 am »
I try to import requirements from a word doc into EA and would like to pass some items (pics, tables, etc.)  to the linked document of an element.
Up to now I didn't found a way to achieve this. Neither the code samples nor the help give a clue about this. ???
How can this be accomplished?
Thanks for suggestions
Kind regards,
Oliver
Re: Creating/accessing linked docs via COM?
« Reply #1 on: May 15, 2006, 03:54:18 am »
Are you using the EA default editor for linked documents? If so, check this post:
http://www.sparxsystems.com.au/cgi-bin/yabb/YaBB.pl?board=general;action=display;num=1147263376;start=2#2
I was unaware of this - thanks again Simon - but perhaps it is what you need. Otherwise I don't know what to do to import specific items into an EA model from an external file.
EDIT:
Without writing an automation program or add-in that is. I have little problem with doing one of those, but I'm not sure that's what you are talking about. Or is it?
END EDIT
« Last Edit: May 15, 2006, 03:55:32 am by Midnight »
owieland69
« Reply #2 on: May 15, 2006, 06:44:06 am »
Sorry, it seems that I missed some important details. :-(
I like to fetch RTF data from an word document and pass it to EA via the COM-Automation interface.
I found no attribute or operation where I can put my RTF data into an EA model element.
Kind regards,
Olli
« Reply #3 on: May 15, 2006, 07:06:03 am »
No Olli you cannot,
This has been requested - or at least the ability to have the Notes for an element in RTF format. No traction at Sparx as far as I know.
