Author Topic: Version 3.60 - Build 643 Released  (Read 26186 times)
sparks
« on: September 19, 2003, 12:07:55 am »
Changes and Fixes in Version 3.60 - build 643
Generate namespace option is used in default templates
Packages set as root namespaces, now generate classes at file scope
The %synchNamespaceBodyIndent% is available for specifying namespace-level indentation during code synchronisation.
Updates to the XML Schema generator and to the associated UML Profile which may be obtained from our website
Fixed error when re-ordering Collaboration messages
Fixed error in XMI import/export to SQL Server - missing diagram hyperlinks
Improved some aspects of XMI import/export when linking back to internal elements
Added support for User Images in custom toolbars. Supplied some default icons in UserImages.bmp, which may be modified or replaced by end user
Fixed issue with importing Metafiles for Stereotypes, both in Stereotype dialog and in importing UML Profiles
Modifications to Code Templates to fix error with C# Public keyword
Added support for <<label>> stereotype on GUIElements - creates a transparent text field
Some fixes in the Delphi code generator
Fixed display of combined foreign and primary keys.
Fixed display of multiple primary keys.
Fixed bug on delete connector on MySQL.
Removed restrictions on creation of foreign keys.
