Author Topic: Importing UML Pattern - XML File  (Read 3834 times)
VINMIS
« on: May 20, 2011, 09:53:58 am »
I am getting error while importing UML pattern XML file. The error message is as follows -
Failed to import UML Pattern '02-Generic 3 Party Guaranteed Delivery'.Pattern too large for database field.
I am using postgre postgresql-9.0.4 repository. EA version is 7.5.
The size of this XML file is 1334KB. I have used the same XML file with EA file based repository and there is no problem in importing this UML pattern.
Re: Importing UML Pattern - XML File
« Reply #1 on: May 20, 2011, 12:21:33 pm »
Check the actual Column sizes in the two DB technologies.  They may be different.
We found a number of anomalies in the various technologies.
See: Inconsistencies in Repository technologies
VINMIS
« Reply #2 on: May 20, 2011, 12:55:30 pm »
Thanks for your reply. I have checked the type of column is TEXT in postgre repository. I suppose this column should be able to contain good size of XML contents. But in my case this columns seems to have problem in accepting large XML contents...
Error is - Pattern too large for database field
