Author Topic: Version 9, Build 904 Crashes  (Read 22049 times)
lubos
« on: May 17, 2011, 09:29:44 pm »
the current official version Version 9, Build 904 doesn't work for me and for every my colleague that had tried  install it.
After starting ea.exe only the message : Program stopped working: is shown.
Has anybody  the same experience?
« Last Edit: May 17, 2011, 09:30:01 pm by lubos »
meierch
  • Modeling we can!
Re: Version 9, Build 904 Crashes
« Reply #1 on: May 18, 2011, 04:14:44 am »
I have now used EA 9 (build 904) for some hours mainly checking features we use in some of our larger models. So far all worked as expected - I only onw problem when I tried to generate a huge report as a PDF directly. I got the error message 'run out of memory' ....
Christian
Regards
Christian
Sunshine
  • Its the results that count
« Reply #2 on: May 18, 2011, 07:35:21 am »
I have also experience the out of memory problem when running reports on large models. Funny enough I fixed it by getting more memory.  :)
Happy to help
« Reply #3 on: May 18, 2011, 08:21:29 am »
It obviously doesn't happen for everyone, I'd recommend first re-downloading the installer and re-installing.
If that doesn't work then you'll need to send in a bug report and provide as much information about your environment as possible.
« Reply #4 on: May 18, 2011, 04:41:30 pm »
I downloaded version 9.0.904.50 of the installer yesterday and it seems to work fine for me.
intrepid
« Reply #5 on: May 19, 2011, 12:54:44 am »
Hi lubos
I am having the same problem.
When I launch the program I get the following error: "Enterprise Architect - UML Development Tool has encountered a problem and needs to close.  We are sorry for the inconvenience."
« Last Edit: May 19, 2011, 03:10:39 am by intrepid »
maxmudit
« Reply #6 on: May 19, 2011, 09:29:07 am »
I'm also facing the same issue. My System config:
core i5, Windows 7 64 bit Professional, 4gb ram
I did get the "UML component has stopped" error once but mostly the EA.exe crashes without giving any message.
Windows event logs show:
Faulting application name: EA.exe, version: 9.0.0.904, time stamp: 0x4dd1f52a
Faulting module name: EA.exe, version: 9.0.0.904, time stamp: 0x4dd1f52a
Exception code: 0xc0000005
Sunshine
« Reply #7 on: May 19, 2011, 11:13:51 am »
I downloaded the trial version of EA V9.0 last night.
It installed fine on Windows 7 Home Edition 64-bit, iCore 5, 6GB RAM and ran fine without any problems for a couple hours.
Is it possible you guys who are having problems are running in a corporate environment where the system admins have tinkered with the operating system for one reason or another and broke it? :-/
« Last Edit: May 19, 2011, 11:15:57 am by phenzell »
Happy to help
intrepid
« Reply #8 on: May 19, 2011, 12:31:37 pm »
Hi Sunshine
This happens whether we install the application on a workstation that is a member of a domain or a standalone system with no restrictions.
DanG83616
« Reply #9 on: May 19, 2011, 02:49:47 pm »
I have been getting various crashes on each of the 9.0 releases. Today's was related to creating a linked document. Unfortunately, I've not been able to debug them. Kind of hard to believe I can crash it in several ways just by using it. Maybe I'm a super power user pushing the envelope. Nope. I don't think that's it.
« Reply #10 on: May 19, 2011, 02:52:00 pm »
Just installed 9.0.904 on a Windows 7 (64 bit) in a standalone (home) environment.
No issues so far...
lubos
« Reply #11 on: May 19, 2011, 05:45:27 pm »
Coleague with WIN 7 has no problems.
Most of us has Vista.
We will do further investigations.... but may be the win version could be the reason...
stefanka
« Reply #12 on: May 19, 2011, 10:25:12 pm »
I have the same problem. I am running two machines, both Win7 64-bit. On one machine I had v7.5 installed previously and v9 crashes upon startup. On the other machine I did not have any version of EA installed previously and v9 works fine.
EeJay
« Reply #13 on: May 20, 2011, 05:12:26 am »
Got a similar error to #intrepid, program had to shut down, lost a bit of work but nothing too hectic.
Using Windows 7 64-bit (see a pattern?)   :-?
Sunshine
« Reply #14 on: May 20, 2011, 08:54:26 am »
Sounds like it might be some weird environment problem so as Simon M  suggests you should raise a bug report and provide Sparks with as much info as you can.
i.e.
  • Version, build and Edition of Enterprise Architect
  • License mechanism - float or fixed
  • Operating system version, service pack & hot fixes
  • Hardware details such as make & model,  processor, ram, etc
As the problem occurs right at startup its possible that it might be something like the floating license mechanism.  :-/
The V9 demo I tested uses a fixed license.
Happy to help
