Author Topic: Version 9, Build 904 Crashes  (Read 21921 times)
stefanka
Re: Version 9, Build 904 Crashes
« Reply #15 on: May 20, 2011, 06:25:04 pm »
I have the problem with both the demo version and the full version. We use a floating license for the full version.
intrepid
« Reply #16 on: May 20, 2011, 06:30:39 pm »
Same problem as #stefanka, but we use a fixed license for the full version.
maxmudit
« Reply #17 on: May 21, 2011, 01:23:48 am »
I have the same problem. I am running two machines, both Win7 64-bit. On one machine I had v7.5 installed previously and v9 crashes upon startup. On the other machine I did not have any version of EA installed previously and v9 works fine.
Could it be that, there are registry entries left from previous EA installs because of which the latest version crashes? I installed  9.904 on Ubuntu using wine and it works.
« Last Edit: May 21, 2011, 01:25:12 am by maxmudit »
« Reply #18 on: May 23, 2011, 04:41:31 pm »
According to the release notes this should be fixed in build 905.
« Reply #19 on: May 24, 2011, 08:22:01 am »
Judging by the ongoing problems that people appear to be having with 905, the "potential crash" fixed in 905 wasn't the one that users are reporting.
Unfortunately, that means that we haven't been able to identify the problem here. So, any bug reports you can send in would be great.
Please make sure to include all of the following.
  • EA Build number.
  • Operating System and Version.
  • A list of currently running applications. (Process Explorer can give this)
maxmudit
« Reply #20 on: May 24, 2011, 09:25:03 am »
The root cause is most likely related to the registry entries left from previous installations which cause 9.904/5 to crash.
