Author Topic: Simulating SysML Parametric Diagram - No Response  (Read 4251 times)
philchudley
« on: April 20, 2011, 01:26:41 am »
Hi All
Not sure how many of you use SysML. I use it infrequently and the last tiime was version 7.5. Although limited, the simulation of a SysML Parametric Diagram worked just fine (including EA Example)
However, upon recreating the same Project example (and running the SysML 1.1 Example in EA EAxample) in version 8.0 ... nothing ... nada
Right clicking the Parametric Diagram and choosing Simulate Diagram... achieves precisely nothing, no dialog not errors just nothing  >:(
Haven't tried Version 9.0 beta 3, but the same happened in version 9.0 beta 1
I am using Windows 7
Anyone else experience the same, and if so has a formal bug report been raised. If not I will raise one
Cheers
Phil
Models are great!
deefer
Re: Simulating SysML Parametric Diagram - No Respo
« Reply #1 on: April 29, 2011, 04:39:01 pm »
Hi
I've tried it with version 8.0 build 856 and it works.
I've opened the "EchoDSP Parametric Modeling Example diagram", righ-click, SysML, simulate, OK
Which version are you using?
Davide
mrf
« Reply #2 on: May 05, 2011, 11:37:29 pm »
Hi Phil,
Just a guess, but it _may_ be due to a restrictive policy not allowing EA to create the scripting object required to run the simulation. Might be worth trying it on a Windows XP box or another machine with a less restrictive security policy to see what the results are.
Michael (no longer affiliated with Sparx, or Mr T)
Best Regards,
Michael
philchudley
« Reply #3 on: May 06, 2011, 12:43:38 am »
Thanks for your replies guys and I have now solved the issue, still can't explain what happed though.
Solution: reverted back to EA version 7.5 - simulation worked
Re-installed EA version 8.0 - simulation worked
Thanks and cheers
Phil
Models are great!
Brad Dillman
« Reply #4 on: May 25, 2011, 09:39:19 pm »
I have this problem, but I don't have v7.5 to try the solution, nor do I really want to. I tried re-installing EA v9.0.906 and the SysML add-in, no success.
