Author Topic: Imported package cannot be edited (906)  (Read 4131 times)
« on: May 27, 2011, 08:22:17 am »
I exported a package (using 906) from an EAP file.
I imported into SQL Server repository.
After import, although unlocked for editing, I cannot change anything (OK buttons etc remain greyed out).
Has anyone encountered this, and got a work around?
Re: Imported package cannot be edited (906)
« Reply #1 on: May 27, 2011, 11:36:44 am »
I tried importing an archived version of the package (created by version 8).
Oddly it works fine.
When I compare the two files I see a lot of
object_style="Locked=true;" that are not in the older file.
« Last Edit: May 27, 2011, 02:25:22 pm by skiwi »
« Reply #2 on: May 27, 2011, 11:58:19 am »
OK, so I edited the XML changing it to locked=false.
Imported and now I can edit some entities, but some objects (eg diagrams) were still not editable.
So it looks like there is something wrong with the 9.0 export
« Last Edit: May 27, 2011, 02:25:49 pm by skiwi »
« Reply #3 on: May 27, 2011, 02:24:17 pm »
Sparx have acknowledged there is a bug.
They have suggested a work around that worked for me
Toggling the security mode "Require User Lock to Edit" off, then on again will clear all locks in the Project.
