Author Topic: Use-cases - unable to resize elements  (Read 5255 times)
nestevao
« on: May 24, 2011, 08:33:34 pm »
Not sure if is a bug or a feature but I no longer can use the 'Same Height', 'Same Width' and 'Same Height and Width' in the use-case diagrams.
In other diagrams is working.
I'm using version 9, build 905.
shirleyj
Re: Use-cases - unable to resize elements
« Reply #1 on: May 27, 2011, 12:22:31 am »
same here..
AndyJ
  • It's only a model
« Reply #2 on: May 27, 2011, 08:47:50 am »
Odd,
I'm also using 9.0.905 and just added a Use Case Diagram, and found that this is working.
I wonder if it varies by license... This is a registered (corporate) version.
« Reply #3 on: May 27, 2011, 08:53:23 am »
If you have 'Allow Elongated Use Cases' turned off on the Objects page of the options dialog then the resize is being prevented.
« Last Edit: May 27, 2011, 08:57:11 am by simonm »
nestevao
« Reply #4 on: May 28, 2011, 02:48:25 am »
OK, a feature not a bug :)
It's working, many thanks.
shirleyj
« Reply #5 on: May 29, 2011, 03:57:48 pm »
thanks!
