Author Topic: Version 9.0.906 Reverse Engineer misplaces classes  (Read 5316 times)
André de Carvalho
« on: May 26, 2011, 10:31:06 pm »
Version 9.0.906 Reverse Engineer (Synchronize existing classes) moves class elements to root folder of import from the namespace respective folders.
Checking : Create Package per Namespace and
Synchronize Existing Classes
Steps
1. Import Source Directory
2. Import Source Directory
=> All class elements are moved to the root folder of the import.
This is a show stopper. We are downgrading to version 8!
Re: Version 9.0.906 Reverse Engineer misplaces cla
« Reply #1 on: May 27, 2011, 11:18:08 am »
I think I reported this with the original 9 Beta.
Still no nswer from Sparx.  Have you reported it also?
I'm running both 8 and 9 on my machine and use 8 for the RE of Code and 9 for the RE of DBs - because each one works better respectively.
However, it is tiresome...
SomersetGraham
« Reply #2 on: May 27, 2011, 05:06:25 pm »
I too have this problem and have reported it to Sparx.
I have found that the 'synch class with code' (F7) works.
Using V12
RainerQ
« Reply #3 on: May 31, 2011, 04:39:00 pm »
I have reported this issue nearly two weeks ago and reminded it last week. I have till now never received a response to this issue :-(
Regards
Rainer
« Last Edit: May 31, 2011, 04:39:22 pm by RQ »
RainerQ
« Reply #4 on: June 09, 2011, 12:56:06 am »
Still no news on this issue?
Regards
Rainer
