Author Topic: RTF documentation with user defined styles  (Read 4583 times)
André de Carvalho
« on: May 20, 2011, 12:48:20 am »
I've defined some new styles in my custom template.
I've applied those styles to {Element.Notes} and {Pkg.Notes}.
After generating, the result RTF document only respects the style in the last paragraph of each note, the first ones are set to Normal.
This happens whenever the notes text has several paragraphs or bullets (may be also in other similar scenarios as well).
The issue happens from (at least) version 8.0.864 to 9.0.906
« Last Edit: May 25, 2011, 11:39:55 pm by acarv »
Re: RTF documentation with user defined styles
« Reply #1 on: May 20, 2011, 06:27:22 am »
We see this issue as well, but haven't pinned it down enough to report.
I do encourage you to submit a bug report
dcb
« Reply #2 on: June 01, 2011, 08:25:42 am »
I'm experiencing the exact same issue--spent loads of time trying to figure out what I did wrong.
I'm still on v.8.0.864. Was about to upgrade when I sw this post. Would prefer to wait for a fix.
BABARN
« Reply #3 on: June 16, 2011, 06:02:29 am »
Our team is experiencing the same issues as well.  Font styles are only applying to the last line of a section.  For example, when we print requirements, the font style will be Times New Roman for most of the description.  The last line will be the style we have chosen to use.
