Author Topic: Tagged Values - Resynch not adding missing tag  (Read 3590 times)
David Rains (bioform)
« on: August 02, 2011, 12:54:02 am »
Running V9 and when I change a stereotype, save it as a profile, then reload the profile and resynch the "new" stereotype it no longer propogates the changes (was at 7.5).
Similar problem if you assign a Enum type before you define it. IF you do that then the drop-down will not be active when you are using the tagged value (previous behavinsor) but you simply correct it by going back to you stereotype force the connection by choosing the created enum from the list, save profile, import, resynch problem solved. This in NO longer the case.
BIG ISSUE for me as I can have hundreds on classes using a stereotype and now have no way to add new tags?!
David Rains
Re: Tagged Values - Resynch not adding missing tag
« Reply #1 on: August 02, 2011, 06:44:49 pm »
A reported bug. No estimate for a fix so far. I still have 7.5 installed which I use for such things.
