Author Topic: DAO.Recordset [3022]  (Read 4922 times)
« on: August 11, 2011, 11:42:35 am »
I'm getting this error when I drag a package into a model document container.
A project integrity check shows nothing wrong.
What can I do, I can't complete a document
Re: DAO.Recordset [3022]
« Reply #1 on: August 11, 2011, 05:19:22 pm »
You could check the dbError.txt (since 9.0 located in the %appdata% and no longer in the program files folder)
That usually gives you some more details about the issue.
« Reply #2 on: August 12, 2011, 07:56:41 am »
12/04/2011 2:51:00 p.m.
The changes you requested to the table were not successful because they would create duplicate values in the index, primary key, or relationship.  Change the data in the field or fields that contain duplicate data, remove the index, or redefine the index to permit duplicate entries and try again.
Context:
      SQL: Select * from t_object where Object_ID=0
Takeshi K
    • Sparx Systems Japan
« Reply #3 on: August 12, 2011, 10:38:00 pm »
Tools | Data Management | Reset IDs, then select Reset All Tables and press Go button may solve the issue.
t-kouno
« Reply #4 on: August 15, 2011, 10:08:15 am »
Great tip thanks. I don't think this was the issue in my case.
I seem to have got round the problem by doing a compact and repair using Access.
« Last Edit: August 15, 2011, 10:09:45 am by skiwi »
