Author Topic: repository connection error  (Read 3764 times)
shirleyj
« on: September 25, 2011, 11:51:38 pm »
we have are own addin that loads info. from the repository.
i have no problem loading info. from a local EAP,
but when connecting to the repository, i recieve an error that says:
"Microsofe OLE DB Provider for SQL Server [-2147467259] Connection failure"
did someone encountered this as well.
Im sure its not an EA issue but still maybe someone can advise a solution?
Tnx in advance,
Shirley
shirleyj
Re: repository connection error
« Reply #1 on: September 26, 2011, 10:15:15 pm »
today i noticed it also happens when generating a document. the same messages appeear.
« Reply #2 on: September 26, 2011, 11:02:56 pm »
Shirley,
Are you able to connect to this SQL Repository using EA without add-ins?
shirleyj
« Reply #3 on: September 26, 2011, 11:29:06 pm »
yes, but when writing heavy queries or generating docs i get the message.
now im thinking that maybe it a version issue?! ill check an old version to illiminate ea issues...
