Author Topic: BPMN install problem  (Read 5402 times)
egentz
« on: May 30, 2006, 06:49:43 am »
after some delay working with EA I downloaded 6.1 / 390
and I downloaded the BPMN add-in
the add-in installer works well, says al is ok
but I didn't see anything about BPMN if I open
EA.
what could be wrong ?
or have I to install something else ?
thanks
ekkehard
Re: BPMN install problem
« Reply #1 on: May 30, 2006, 06:54:42 am »
the add-in installer works well, says all is OK
EA.
thanks
ekkehard
Did you search for BPMN in the forum.  A number of users have provided their experiences...
Try it..
bmioch
« Reply #2 on: May 31, 2006, 06:34:02 pm »
Once BPMN is installed, you need to activate it in EA.
From the main menu at the top of the screen, select Add-Ins.
If BPMN has installed correctly, it should have its own sub-menu.
Go to this sub menu and select load.
« Reply #3 on: May 31, 2006, 06:42:32 pm »
You may also have to reset your main menu to see this stuff.
NB: Performing the reset will remove any customizations you have made to the menu. You will have to set it up again.
Within EA - it is not necessary to open a project - from the main menu select Tools / Customize. Click the Menu tab, and then click the reset button.
Once you've done that you should see the Add-in menu. From there follow the instructions bmioch provided.
egentz
« Reply #4 on: June 01, 2006, 01:18:55 pm »
thanks !
resetting the menu does it - now I can see the add-in menu
and BPMN ist there
regards
ekkehard
