Author Topic: Web Template  (Read 4083 times)
toajax
Web Template
« on: June 06, 2006, 10:37:00 am »
I have defined a class A with some protected attributes. I have defined another class B, derived from A. I have used the "Override attribute initializers" feature on class B, to override the value of an attribute from class A.
I am now using the HTML doc generation feature to generate documentation for the two classes, but the documentation for class B, does not show the overridden attribute nor, does it show the overridden value.
Any idea how I can get the HTML doc generater to output that?
Re: Web Template
« Reply #1 on: June 06, 2006, 12:31:23 pm »
Off hand I don't know.
But, can you generate the documentation through the RTF documentation function (either one)?
toajax
Re: Web Template
« Reply #2 on: June 06, 2006, 09:47:23 pm »
No the RTF documentation does not generate it either.
Re: Web Template
« Reply #3 on: June 07, 2006, 05:29:00 am »
I suggest you report this as a bug, since there would appear to be no way to show the override in your documentation. If Sparx has a handle on this they will get back to you. Otherwise they probably need to be made aware of the defect.
There is a handy short cut to the page. From the EA main menu you can use Help / On-line Resources / Bug Report Page.
