Author Topic: Debug Issue  (Read 3557 times)
qaus
Debug Issue
« on: October 25, 2011, 06:46:10 pm »
I am the new User of Enterprise Architect.There is a problem when I debug my application .The step I have followed are:
1. Create the model having no. of classes.
2.Created new Script in Execution Analyzer and added command for Build.
3.When I debug the Application .Error occurs as"Failed to load Common Language Runtime"
Is it necessary to install Visual Studio for debugging the application??
Re: Debug Issue
« Reply #1 on: October 26, 2011, 08:54:34 am »
No, you don't need Visual Studio.
I don't have a lot to do with the debugging, but I have seen several instances where a .Net application was set to build as 'Any CPU' which on a 64 bit system means 64 bit and as a result EA is prevented from debugging it. The solution is the build for x86.
I hope that helps.
