Author Topic: Reference data export: matrix profiles  (Read 4506 times)
Uffe
« on: November 10, 2011, 10:43:10 pm »
Hi!
I've got a couple of diagram matrix profiles defined in a project (visible in the Resources window), which I'd like to transfer to another one.
Problem is, when I try to export them (Project - Model Import/Export - Export Reference Data) I end up with an XML file which contains only the <RefData> tag - no actual contents.
Has anyone got any input?
I'm on 9.0.905 on XP SP3.
Cheers,
/Uffe
Luis J. Lobo
  • IT Consultant
Re: Reference data export: matrix profiles
« Reply #1 on: November 11, 2011, 03:16:44 am »
The exportable reference data regarding the "Diagram Matrix Profiles" is related to the swimlanes/matrix of the diagrams, not the "Relationship Matrix".
What are you trying to export? The relationship matrices are not exportable...
Luis J. Lobo
  • IT Consultant
« Reply #2 on: November 11, 2011, 03:21:02 am »
Note that the relationship matrices points to 2 packages (source and target) with its own GUIDs, and this matrix definition is not valid for another Repository (unless the packages have the same GUIDs). That's why they aren't exportable.
Uffe
« Reply #3 on: November 11, 2011, 05:46:36 am »
Ah, I see. Well that's alright then.
Thanks!
/Uffe
