Author Topic: Version 3.60 - Build 644 Released  (Read 23822 times)
sparks
« on: September 23, 2003, 11:48:37 pm »
Changes and Fixes in Version 3.60 - build 644
Modified Workspace Views toolbar to allow toggling of docked windows (on-off)
Added Configure Appearance menu option to element context menu
Fixed problem with some docked windows first appearing with no "X" cloce button in the top right corner
Fixed issue where Rolenames on association between two tables were being suppressed, even when Foreign Keys were not defined
Modified  VB parser to treat Enums in .cls files as inner classes
Modified VB.Net parser to allow _ in op declaration
Added code in Override Implementation dialog to support VB implemented interfaces.
Fixed issue with Vb, VBNet operation implementation for inherited interfaces
Corrected problem with element properties dialog appearing offscreen in some instances
Modifed foreign key dialog to only show FK's associated with current association
Fixed problem with Print List function in several places causing exception in Unicode version
Released first version of SPEM UML Profile (see http://www.sparxsystems.com.au/spem_profile.htm)
Fixed problem in automation interfce with Aggregation property on ConnectorEnd Object
Fixed problem in automation interface when deleting a Connector from a Collection
Changes to XMI 1.0 imort/export to pick up EA tags when round tripping
Modified use of XMI local path setting for use with Version Control
Added "Parameter Impl" code generation template to allow for correct generation of operations having parameters with default values
